Message 1 of 5
BT hand set is muting both outgoing andincoming calls , HELP
4 REPLIES 4
Message 2 of 5
Re: BT hand set is muting both outgoing andincoming calls , HELP
Which BT handset do you have?
RIC9380
Message 3 of 5
BT6500
Message 4 of 5
That model has been around for quite a while (about 2011) so I would start by renewing the batteries.  You need to get 2 x AAA Ni-MH 750 mAh rechargeable batteries and see if that resolves the issue.
Message 5 of 5
Thanks for your help
