Message 1 of 7
BT3570 twin
I have just purchased a BT3570 twin setup to replace a failed one. It works fine but I have a handset and base from the previous setup which seem OK. I want to pair these with my new setup but I am having no luck. I have followed all the steps suggested in the manual but with no luck. Has anyone any suggestions?
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: BT3570 twin
Did you deregister it from the old base first?
Message 3 of 7
Re: BT3570 twin
Unfortunately the old base failed which prompted me to sign purchase a new setup. How do I deregister it in these circimstances? I have tried re-entering the default PIN of 0000 but that hasn't worked.
Anonymous
Not applicable
Message 4 of 7
Re: BT3570 twin
Try a reset as per P.53 of the manual.
Message 5 of 7
Re: BT3570 twin
Thanks. I have tried a reset and deregistered from the previous base. Now when I scroll through the settings and get to "Advance Set" I get the message "Deregistered" I press OK and it calls for a PIN which I assume is the default PIN of 0000. I enter this and the phone goes "Searching" and then "Fail". I guess I should abandon the whole thing!
Anonymous
Not applicable
Message 6 of 7
Re: BT3570 twin
If you're saying the handset was successfully deregistered then just follow the registration process on P.55.
If not then probably best you call the helpdesk to talk you through while you have the phone in your hand.
0800 145 6789
Message 7 of 7
Re: BT3570 twin
Thanks so much, that solved my problem. I only received the Quick Setup manual with the phone but I have now downloaded the full manual. I should have done this at the start. Thanks for your help.
