Message 1 of 9
BT4600 phone set up
How can I unmute all my saved numbers as I cannot dial out on some, as soon as I unmute the number I can use it or is it the phone itself that needs unmuting if so how do I do it
8 REPLIES 8
Anonymous
Not applicable
Message 2 of 9
Re: BT4600 phone set up
No idea what you're referring to?
Message 3 of 9
I was dialing out and getting the engaged tone but I found that if I dialed the number or used speed dial or numbers saved in the phone book and at the same time pressed mute/unmute the next time I dialed it it would connect, seems strange to me also. I also cannot understand how they all became muted
Anonymous
Not applicable
Message 4 of 9
"Mute" simply disconnects the microphone when on a call, you cannot mute a contact. So something odd going on there. Maybe try powering down the base & handsets for half an hour & try again.
Message 5 of 9
Sorry, when you say power down do you literally mean unplug from the wall. Thanks for your patience
Anonymous
Not applicable
Message 6 of 9
Unplug the base from the mains & maybe remove the batteries from the handset(s) for good measure.
Message 7 of 9
I have tried your suggestion but no joy
Anonymous
Not applicable
Message 8 of 9
Just a thought but are you actually unable to dial out? Could it be that what you think is an engaged signail is actually the1571 service alerting you to a voicemail?
Message 9 of 9
No, I am not able to dial out, there are just a couple of numbers that will work on speed dial
I have set up the old phones and still cannot dial out so I must assume it’s the line set up, I will contact the supplier
