Message 1 of 5
BT8500
Why does my BT8500 cut out mid call it has new batteries
4 REPLIES 4
Message 2 of 5
Re: BT8500
Hi @Jackiewelsh,
Welcome to the BT Community
Is the handset losing power/turning off during the call or the handset stays on but just the call itself is dropping?
Is it happening on every call or is it intermittent?
Alex
Message 3 of 5
Re: BT8500
The calls drop intermittently.  The screen goes back to the start .  I've had the line checked and no faults found. I've just spoken with BT agent who says the base is faulty and they no longer make this model so I've ordered a new set
Message 4 of 5
Re: BT8500
@Jackiewelsh Thanks for coming back to let us know what you have found out regarding the issue. Hopefully the issue will be resolved with your new set, let us know if you need any further help.
Alex
Anonymous
Not applicable
Message 5 of 5
Re: BT8500
If by that you mean the phone reboots with a BT logo, you almost certainly just need new batteries.
