Message 1 of 13
Smart Hub 2 , Digital Voice, BT8500
I've just been migrated to Digital Voice.  Smart Hub 2 is working fine. I plugged the base unit of the 8500 into the hub. The hub has recognised both handsets.  The phones are working fine. I can receive and make calls. However, There is no dial tone, which is a bit puzzling. I tried with an older phone, a BT Relate 600 and it works perfectly too and there is a dial tone. The The 8500 had a dial tone before Digital Voice, so the problem seems to be with the 8500. I've tried various things like powering off and resetting the hub, powering off the 8500 base unit, but no luck. As I said both 8500 handsets are working, but it would good to have the reassuring dial tone back. Anyone have any ideas?
12 REPLIES 12
Message 2 of 13
Re: Smart Hub 2 , Digital Voice, BT8500
Message 3 of 13
Have you checked there is no messages on the answering machine 1571?
Message 4 of 13
Thanks for your quick response. Unfortunately 1571 is empty.
Message 5 of 13
Hi @ColinS2
Thanks for coming to the community.
If you have no dial tone on this phone, please give us a call and the team can check everything is set up correctly at our end and run through some troubleshooting with you.
Let us know how you get on 🙂
Leanne.
Message 6 of 13
Hi Leanne.
Thanks for your reply. As I said, the internet and in/out calls and ringing all working fine with 8500. And if I use the old Relate 600, I get a dial tone. Puzzling!  What number should I call?
Regards
Colin
Message 7 of 13
@ColinS2
Noticed you’ve said that ‘the hub recognises both [8500] handsets…’
I’m assuming you’ve plugged the 8500 base unit into the Smart hub. In which case there’s no need to pair the handsets with the  hub at all..
I’m wondering if the hub is getting confused in that it’s seeing both the 8500 base unit and the individual handsets wanting to make a call at the same time?
Message 8 of 13
Hi @ColinS2
If you do need to call, you can find all of the contact details for our tech guides on our Contact Us page.
Michael
Message 9 of 13
Yes that puzzled me, although the phones worked.  I deregistered them in the Hub Manager, and now the only thing listed under Phone is Adapter 1.   The base unit is plug into the adapter.  I've tried it at the Smart Hub too, but still no success with dial tone. Otherwise phones are working fine.  The old Relate 600 gives a dial tone when plugged into the Hub, and when plugged into the adapter.
Anonymous
Not applicable
Message 10 of 13
Some older phones have required the addition of a microfilter to the SH2 to provide the ring wire. I'd be surprised if the 8500 required that but no harm trying if you have one kicking around.
