Message 1 of 3
BT8600 - intermittent/engaged dialling tone
My base station and 2 additional handsets all have an intermittent (engaged) dialling tone. I can make and receive calls. I have DV but it is not the voicemail (noting previous replies to a similar issue I dialled 1571 but have no messages). I’ve re-booted hub and disconnected /reconnected phone but to no avail and been through BT to confirm line is working ok. Any ideas please?
2 REPLIES 2
Message 2 of 3
Re: BT8600 - intermittent/engaged dialling tone
Try leaving a message on 1571 and then pick it up.
Message 3 of 3
That has solved it! You’re a genius - thanks so much.
