Message 1 of 6
BT 1572
Why does my bt 1572 system not recognise my mobile phone number when I have no numbers blocked?
5 REPLIES 5
Message 2 of 6
Re: BT 1572
Do you mean when you call your landline from your mobile its going to 1572 voicemail?
Message 3 of 6
Re: BT 1572
Yes, when I call from my mobile I get the 1572 voice mail? but other people can get through on their mobile ok.
Message 4 of 6
Re: BT 1572
I guess you've checked your block list online in mybt? Also is there a chance you've set block withheld numbers and you're withholding your mobile number?
Message 5 of 6
Re: BT 1572
I have checked that my mobile number is not in blocked list. I've also checked it's not blocked in landline phone list of numbers.
Message 6 of 6
Re: BT 1572
Hi @David719
If the number is not showing as blocked anywhere, I'd recommend getting in touch with our tech guides so they can have a look into this further and see if they can find what is causing the number to not come through.
Michael
