Message 1 of 3
Bt digital phone
I have just received a phone call from a friend and when the call ended I accidentally pressed the red block the caller button instead of the red call end button and there is a way to reinstate the caller I can’t remember how to do it.
Any help would be appreciated.
2 REPLIES 2
Message 2 of 3
Re: Bt digital phone
Hi @rogill
Log in to your account at BT.com, select 'Your Products' then Manage Digital Voice.
Scroll down a bit and select Manage Call Protect, then click on 'Manage' under Your Recent Callers. Find the number and select 'More' on the right hand side and select Remove From Blacklist.
Message 3 of 3
Good morning Andy,
Many thanks for your quick reply.
I have followed your instructions and have removed the blocked number.
Regards
Roger
