Message 1 of 19
Caller Display no longer works on my landline phone, now that I have changed to digital voice
My home phone is now working with digital voice, connected to my new hub, but, Caller display does not work.
I have a list of contacts on my phone , but none of them are displayed when anyone calls. They are all listed as No Number.
18 REPLIES 18
Message 2 of 19
Re: Caller Display no longer works on my landline phone, now that I have changed to digital voice
Message 3 of 19
@chris661
Its not enabled by default, you have to add the feature yourself via the Manage BT Digital Voice option within MyBT.
https://www.bt.com/help/landline/digital-voice--how-do-i-use-my-calling-features-
Message 4 of 19
Was unable to add this feature myself, as no option in My BT - BUT I called BT and an assistant set it up for me. Now working.
Message 5 of 19
Thanks for coming back and letting us know how you got this sorted @chris661
Have a lovely day 🙂
Leanne.
Message 6 of 19
I have just renewed my contract and have lost my caller display.  When I log i to my bt  I can't find the option to manage digital voice
Message 7 of 19
Hi @mar53
Thanks for coming to the community.
If you can't find the settings in your My BT account, please get in touch with our Broadband tech guides, they will be happy to help you get this sorted.
Let me know how you get on.
Leanne.
Message 8 of 19
Hi,
Could not access the settings to activate caller display on bt app via mobile phone, just found them using the laptop, all sorted now, thanks.
Message 9 of 19
Thanks for letting me know @mar53
Glad this is sorted for you.
Leanne 🙂
Message 10 of 19
Caller Display 1500 wall mounted unit no longer works as I'm told it is incompatible with digital voice?
