Message 11 of 19
Re: Caller Display no longer works on my landline phone, now that I have changed to digital voice
My caller display is working now bt deactivated it when I renewed my contract
Message 12 of 19
Hi @allan7,
Welcome to the BT Community
Have you spoken to our technical team regarding your caller display not working? It is possible as mentioned by others in the thread that during the change to digital voice the caller display feature has been disabled and if so they should be able to re-enable it for you.
Alex
Message 13 of 19
The caller display was deactivated by bt when I renewed my contract,  I had to go online and reactivate
Message 14 of 19
This was all sorted out months ago.  It was re-enabled by the technical team.
Message 15 of 19
The Caller Display on my phone handset works but the wall mounted BT CD1500 with the much larger screen that I find so helpful does not. Can it be reactivated?
Message 16 of 19
Is it connected to the green socket at the rear of the hub?
Message 17 of 19
The BT CD1500 User Guide states that the "product is intended for connection to analogue public switched telephone networks and private switchboards in the United Kingdom." It's a 25 year old product!
Message 18 of 19
Agreed, but no reason for it not to work if connected to the ATA in the hub.
Message 19 of 19
YES !! Thank you. Connecting the ageing CD 1500 to the green slot at the back of the router works. Wonderful.
