Message 1 of 6
Caller Display stopped working three weeks after starting with Digital Voice
Caller Display worked for a while after I started using Digital Voice on 19th Dec last year but over the last couple of weeks I now mostly see just " Incoming Call" when receiving calls on my BT4500 handset (via the DV adapter). I've checked to see that I am still subscribed to the Caller Display service so I can't understand why it's not working.  Interestingly I've found a  number is displayed when receiving calls from a number I has previously called.
5 REPLIES 5
Message 2 of 6
Re: Caller Display stopped working three weeks after starting with Digital Voice
Message 3 of 6
Sorry, nothing in the Digital Voice FAQs look is useful to me.
Message 4 of 6
Does caller display work if you plug the phone base unit into the phone socket on the back of the Smart Hub 2, as there have been reports of issues with the DV adapter and caller display, with some phones.
It may also be worth removing the power to the BT4500 base unit for about a minute, as its possible for the DECT communications between the base and the handset to lose sync.
Message 5 of 6
Removing the power from the base unit for a couple of minutes seems to have done the trick. Thanks for the tip.
Message 6 of 6
Excellent 😀
Its not unknown for DECT communications to lose sync.
