Message 1 of 6
Caller ID no longer working
I've had caller ID working on my BT landline for many years, but the display on my old phones got so bad I never noticed if it was still working.  I've just got a set of BT Premium phones but there is no caller ID showing so it looks like it's no longer active.
Is there some way to get it re-enabled on my landline?
5 REPLIES 5
Message 2 of 6
Re: Caller ID no longer working
You can try going to MYBT and see if you can activate it from there or alternatively phone CS 03301234150 and they will help you
Message 3 of 6
Thanks, but it's already showing as enabled under My BT.
Customer Service aren't available now so I'll try them tomorrow.
G
Message 4 of 6
Trying CS but using the landline tells me to hang-up so they can run tests, and on my mobile, it just gives an automated text.  The Message Us button doesn't work on MyBT either.
How are you supposed to actually speak to someone?
Thanks, Graham
Message 5 of 6
They phoned me back, and hopefully all sorted now - re-enabled caller ID.
Message 6 of 6
Thanks so much for coming back and letting us know @gray3
Glad to read this has been sorted for you.
Leanne.
