Message 1 of 5
Can 2 people take part in same outgoing call from BT Internet phone
Basically is it possible for 2  people to participate in the same outgoing call using 2 phones ie not just on speaker?
4 REPLIES 4
Message 2 of 5
Re: Can 2 people take part in same outgoing call from BT Internet phone
Yes, along as both are connected the same way. There is no communication between digital Voice handsets and analogue handsets connected via the green socket on the hub.
Message 3 of 5
If call is made on phone 1 how does phone 2 connect in?
Message 4 of 5
Press the green button twice
Message 5 of 5
Thanks will try that
