Message 1 of 2
Can i use a BT Décor 2600 with a BT 4600 Twin?
Hello ! , Is it possible for me to use a BT Décor 2600 and BT4600 twin together. both of them have Truecall blocking and Answering Machine. I know i can turn off the Answering machine on one of them and the other will work as the Answering Machine but will the Truecall work okay if its enabled on both Telephones. or will it only work if enabled on one. i hope im making sense. i ordered a BT Décor 2600 the other day as i only have the BT4600 twin and need a extra Telephone but i realised when looking up about it people are saying it can work and some are saying the décor 2600 will not work with other phones.
Thanks in Advance for anyone who can help answer my question
Tags (2)
1 REPLY 1
Message 2 of 2
Re: Can i use a BT Décor 2600 with a BT 4600 Twin?
Hi @Telephone123
Welcome to the Community.
You can have a look at our Can I use a different type of BT cordless phone with my existing base page, which may help find the answer you're looking for.
Ali
