Message 1 of 6
Cancel landline
I'm in contract on FTTP for broadband but do I need a landline? as I'm not using
5 REPLIES 5
Message 2 of 6
Re: Cancel landline
@belnat
you need to pay for the landline connection whether copper or Fibre and that is included in package cost.  do you still have the ability to make and receive calls on your landline phone whether PSTN or DV?  if so you can change to broadband only and may save up to £5pm but you will need to start a new contract
Message 3 of 6
Re: Cancel landline
Thanks, appreciated.
It's showing as FTTP in contract until Sept 2023, but unlimited calls at £11pm as not? I'm not using phone so would like to stop. A phone call to BT would be best?
Message 4 of 6
Re: Cancel landline
the phone call packages are add-on so have you tried going to MYBT to make the change
Message 5 of 6
Re: Cancel landline
Thanks!
Message 6 of 6
Re: Cancel landline
if you want to do away with ability to make/receive calls ( broadband only) then you will need to start a new contract and best phone options team 0800800030
