Message 11 of 12
Re: Changeover to Digital Voice
@nfee … do you still have access to your old analogue line? If so plug a phone in and see if calling your number rings on the old analogue line.
I had a similar issue when I converted to Fibre 900 and Digital Voice. Whilst I could call out on my new DV service, I wasn’t getting incoming calls, however plugging in to my old analogue line I could get calls through. I could even call my own number from my DV handset and it would call the old analogue line. Mine was down to the order for my Fibre getting stalled somewhere in the BT system.
Message 12 of 12
Many thanks for your help. Finally all sorted today. The number had still failed to be ported across from old PSTN system. I called them today and it is finally working.
As Etta James would say "At last".
Obviously there will be lots of digital change over problems.
