Message 11 of 15
Re: Compatibility of different cordless landline phones
Ah... found it... it's set on multicall - is that the one it should be on?
Message 12 of 15
I think multi call is found using BT phone and then settings then line settings
Message 13 of 15
Entirely up to you.
Multi call means you can make/receive 2 calls simultaneously.
Message 14 of 15
Ah... I see. I didn't even know you could do that. I might try switching it and see if by any chance it makes the whole darn thing work more consistently. Thanks for your assistance.
Message 15 of 15
Worth a try, it is a bit of a double edged sword.
