Message 21 of 34
Re: Copper Landline
That isn't your connection speed, its your throughput speed.
Message 22 of 34
Re: Copper Landline
so how do I get a connection speed please
Message 23 of 34
Re: Copper Landline
From the stats page of the Vigor.
Message 24 of 34
Re: Copper Landline
I do not have any login
Message 25 of 34
Re: Copper Landline
I suspect the router address will be http://192.168.1.1 and the username and password admin and admin.
Message 26 of 34
Re: Copper Landline
No  idea how to do that  sorry
Message 27 of 34
Re: Copper Landline
Just click on the link in my post.
Message 28 of 34
Re: Copper Landline
No Luck
Message 29 of 34
Re: Copper Landline
Did you get a login page but the credentials didn't work or did you not get a login page?
Message 30 of 34
Re: Copper Landline
Login page  -  credentials did not work
