Message 11 of 34
Re: Copper Landline
@OBOBE wrote:
1. Copper landline - Voice fine,  Internet fragile to useless,
I fail to see how that can be the case. They are both carried by the same pair of copper wires, if one fails so does the other.
Message 12 of 34
Re: Copper Landline
Thank you.  I am 700m from the cabinet. No idea where the exchange is located.
My connection is variable  - at best 20Mb - at worst less than 7Mb [download]  - upload make a snail look fast.   I currently have a direct landline to eanble voice in a power cut.
If we have a pewer cut there is no internet?
V grateful
Message 13 of 34
Re: Copper Landline
What would you expect the copper to deliver as an internet connection?
Message 14 of 34
Re: Copper Landline
700M from the cabinet with a good line should give about 30M-40M. If you have an aluminium cable, it could be anything.
Message 15 of 34
Re: Copper Landline
If we have a power cut there is no internet
@OBOBE  then you would need to provide power backup to the BT Smart Hub 2, a 12V supply is all that is needed.
Its not clear whether you have an ADSL or a VDSL connection as the speeds you quoted could be either, as ADSL can deliver up to 20Mbs.
If you are that close to the cabinet, then I would expect a much faster VDSL connection than 20Mbs unless you have a poor quality local cable.
Message 16 of 34
Re: Copper Landline
1. how do I determine ADSL or VDSL.
2. I d o not have BT smart hub but Vigor 2762ac and do not undestand anything about that area.
Message 17 of 34
Re: Copper Landline
Does the Vigor give the modulation type in the management page? If so, what is it?
Message 18 of 34
Re: Copper Landline
WOA   you are getting me 'off piste'  I can find not ref to a management page or modulation type. in h equick start guide - sorry.
Message 19 of 34
Re: Copper Landline
How do you know what connection speed you are getting if you can't access the stats page in the Vigor?
Message 20 of 34
Re: Copper Landline
Via website speed test
