Message 1 of 3
Cordless phone extensions
How do i set up my current cordless phone setup using Digital voice. I have the main unit in the dining room with extensions to 2 bedrooms and one in the garage. The main (old) BT phone is in the hall but rarely used. I need the extensions due to a vulnerable relative who needs total assistance but is likely to try to make her way around without warning which is why i need the phones in the locations i have them (apart from the garage)? If i plug the main unit into the hall (where the hub is) will my extensions then work? Please, no condescending replies. Thanks.
2 REPLIES 2
Message 2 of 3
Re: Cordless phone extensions
Message 3 of 3
You simply need to plug the base station in the green socket at the rear of the hub. Everything will then just work as before.
