Message 1 of 6
DECT phone and upgrade to Full Fibre
I will be getting upgraded to Full Fibre in 4 weeks time.
My current Hub does not have a socket to plug in my DECT phone.
Will an appropriate Hub be sent to me, will the engineer provide one or do I need to request one?
5 REPLIES 5
Message 2 of 6
Re: DECT phone and upgrade to Full Fibre
you will get a new SH2 sent to you as you need WAN port for FTTP and SH2 acts as base station.  you should also get a DV phone
Message 3 of 6
Thanks for your prompt reply.
Message 4 of 6
Just wanted to point out that, in my experience,  you do not automatically get a DV phone, you need to phone up and ask for one.
Message 5 of 6
Thanks,
I will bear this mind (and the SH2)
Message 6 of 6
@if
It seems to be a bit hit or miss as some seem to get a DV phone sent with the SH2 whereas some only get the hub and need to request the phone.  There is no problem requesting a new DV phone
