Message 1 of 3
DV Adapter instructions
TL:DR  the instruction leaflet sent with the "Home Phone Adapter" needs a re-write.
The longer version:
Got switched to Digital Voice earlier in the week.  Unable to use it without a DV adapter as router not in same place as telephone.  Took multiple attempts to get someone to send me a DV Adapter.
DV Adapter arrived today.  Instructions say "if you changed you base PIN on your Smart Hub from the default 000..."
But there's no PIN anywhere in the Smart Hub 2 admin page.  And people have asked about this a few times in this community - with no solution found.  The nearest I can see to a solution is a discussion of a BT Hub Base - i.e. a DECT system base unit.  So, nothing to do with a Smart Hub.  The leaflet needs to be re-written to save customers hours of fruitless searching.
2 REPLIES 2
Message 2 of 3
Re: DV Adapter instructions
Message 3 of 3
Not sure from your post if you have managed to set up the adapter but here are the online instructions which look simple enough:
Set up and use a Digital Voice Adapter | BT Help
I am presuming the instructions you are referencing are paper ones which come with the adapter? says if you have changed your base pin, I would read that to say if you have changed it you need to do something different, as you didn't know what it was referencing I would have just ignored it and carried on as you didn't change anything.
