Message 11 of 15
Re: DV Handset Issue - Batteries?
@barnpiecewrote:
I have two DV handsets and only use one base to charge (the other does not have its power supply connected). I swop the phones over ever 12 hours so they spend half the time on charge. The reason I do this is that many years ago a BT engineer told me that the batteries will last much long if allowed to discharge in this way (and it is true).
I have been using these two phones for over3 years now with no problem. The batteries still charge fully and are healthy
Richard
But how would that work for me?  I've named one handset "Downstairs" and the other "Upstairs" ....... 😉
Message 12 of 15
@ploppy
You could take phones off charger in the morning and put back on charger overnight  or you could do it other way round if that suited you better
Message 13 of 15
@imjollywrote:
@ploppy
I had wondered about smart plugs, but I may go for the low tech solution for now!
Message 14 of 15
Mine are labelled Day and Night, with Day downstairs during the day.
Message 15 of 15
Public Libraries usually have Which? magazines.
