Message 1 of 3
DV Phone Charging
I've had problems with these phones (I've got three) ever since I've had them - mostly battery related I reckon.  For example, I was on a call recently and although the phone was fully charged the call cut out after about 10mins i.e. the phone kept rebooting itself - the usual process, BT logo, synchronising data, etc.  I was on speaker phone, so I'm guessing that had a part to play - although I'd still expect it to last for more than 10mins.
The batteries in all phones are relatively new - Eneloop 800mAh.
Anyway, ignoring my phone rebooting problem for now, I decided to follow the advice of some people on here and not leave the phones on their chargers permanently.  All 3 phones discharged over a few days but I didn't let them get to empty.  After putting them back on their chargers they duly re-charged themselves to what appears to be full.  However, on all phones the charging symbol is still on.
Simple question: should the charging symbol disappear when the phones are fully charged?
2 REPLIES 2
Message 2 of 3
Re: DV Phone Charging
is the charging symbol still there when you remove the phones from the base or disappears?  if disappears then it probably is just a trickle charge when on base keeping phoned topped up
Message 3 of 3
Charging symbol disappears when I remove the phone from the cradle but comes back on the moment I replace it. I could have sworn that it didn’t show charge symbol permanently before.
