Message 1 of 6
DV adaptor
I have just been switched over to Digital Voice . I can receive and make calls when phone plugged into router but I can only make calls if I use adaptor and not receive them which would be my preference due to location .
Any suggestions how to solve
5 REPLIES 5
Message 2 of 6
Re: DV adaptor
Try connecting an old style filter to the adapter and see if that works
Does the phone receive calls if connected to socket on back of hub
Message 3 of 6
Re: DV adaptor
Which make and model of phone are you plugging into the adaptor please? Some older phones won't work fully in conjunction with them.
RIC9380
Message 4 of 6
Re: DV adaptor
Yes I have tried filter having read posts from “Ryan “ a couple of years ago .
Yes I can receive calls if connected to hub .
I have three B&O Beocom 6000 handsets with PTSN base and let’s face it they are much more stylish than BT phones !  As it works if plugged in to back of router may need to leave that and find aesthetic solution to tangle of wires and bits of kit
Message 5 of 6
Re: DV adaptor
Very nice handsets, DW88. I had a corded B&O Beocom 2400 plugged into the Hub which worked fine (replaced with a Gigaset DX800A plus DECT extensions) but I don't have the BT adaptor so can't really comment further. I believe the Beocom 6000 handsets are still being manufactured but haven't been available in the UK since 1998.
Message 6 of 6
Re: DV adaptor
It can be quite surprising how long the older phones last. I am not on digital voice yet but have fairly old but very lovely  and beautifully simple corded landlines.
