Message 1 of 13
just installed 900 full fibre bt today with bad speeds and something about digital voice call
now its asking me to install digital voice i dont know how to do that can u send me a link to a tutourial
also my full fibre 900 installed today everything is fine just green blinking on LAN option on open reach modem
and im not getting 700 mbps speed its like 200mbps engineer installed it today so i dont know whats going on
12 REPLIES 12
Message 2 of 13
Re: just installed 900 full fibre bt today with bad speeds and something about digital voice call
Message 3 of 13
IF you check hub manager can you see your phone number and if so does it show active/ configured?  If so you can object your existing phone to phone socket on back of hub
Are you checking speed using an ethernet cable and running   https://speedtest.btwholesale.com/
Message 4 of 13
5ms ping 162 download and 110 upload also i will plug the phone into back of hub since number is there now its just speed problem i have the open reach modem flashing green on Lan and plugged on port number 4 on hub but also the gfast is in the WAN slot if that makes sense thats how the engineer set it up
Message 5 of 13
If you mean your copper G.Fast master socket is connected to the DSL socket (not the WAN socket, LAN port 4 is the WAN socket), you should remove it.
Message 6 of 13
copper G.fast master socket is connected to the grey wan port my full fibre is connected to port 4 on the hub if that makes sense also there green flashing where is says LAN on openreach modem
Message 7 of 13
The master socket should no longer be connected to anything and the ethernet cable from ONT - FIBRE MODEM- should be connected to wan port 4 on SH2
Message 8 of 13
oh ty i will do a speedtest after
Message 9 of 13
i just did another speed test doing that site u linked still same speeds even when i unplugged master socket everything setup right just dont know about the green blinking LAN on open reach modem i thought it was supposed to be solid green not blinking or is blinking mean its working
Message 10 of 13
i tested on bt app it says 941mb download 112mb upload but my stay fast is 150mb and10mb idk why thoe my stay fast should be 700mb if i ordered 900 full fibre not unless i havr to wait for stay fast to change in next ten days
