Message 1 of 9
DV keeps dropping out and lag
hi, my dv phone and 2 plugged into routr have started dropping out after 30-50 minutes and get a lag in conversation. any ideas?
i have fibre 900
8 REPLIES 8
Message 2 of 9
Re: DV keeps dropping out and lag
Message 3 of 9
Try a factory reset of the hub via the recessed button at the rear, but make sure you back up your contacts before you do and restore them afterwards as they will be deleted by the reset.
Message 4 of 9
Possibly a poor quality Internet connection. A delay in conversation normally means that data packets are being dropped.
Message 5 of 9
surely with fibre connection should be goo
Message 6 of 9
Indeed, hence suggesting resetting the hub.
Message 7 of 9
thank you. I will do it
Message 8 of 9
all reset, waiting to see if it works.
thank you for the support
Message 9 of 9
thank you. resetting the hub sorted everything.
