Message 1 of 3
Digital Phone Not Configured
My Mother has moved home. BT disconnected her Broadband and landline two days early.
At the new home I have connected the BT hub and Hybrid Connect.
BT Hub = Blue Light
EE Hybrid Hub = Blue Light (Signal strength good)
Connected the digital phone OK. But get "Unable to make or receive calls" Press help and it says "no internet connection available"
Internet access is working. On the hub manager it has the phone as "Not configured"
My Mother lives on her own and is classed as vulnerable. She needs a working phone for emergencies. Her mobile is having issues in the new location.
The question is which is the best number to call for a digital phone not working? Is there a particular team and can it be escalated due to her current lack of a reliable phone in an emergency?
I have tried a factory reset on the hub to no avail.
2 REPLIES 2
Message 2 of 3
Re: Digital Phone Not Configured
is your mother registered here
https://www.bt.com/content/dam/bt/help/including-you/BT_Free_Priority_Fault_Repair_Scheme.pdf
try phoning 03301234151 report phone fault
Message 3 of 3
@208197511001B
Welcome to this user forum for BT Retail phone and broadband customers.
I am wondering if its just the Hybrid Connect providing the Internet, and not the main broadband connection.
If that is the case, then the phone will not work.
Turn off the Hybrid Connect and see if you still get an Internet connection.
If not, then the main broadband connection is not working, which is why the phone does not work.
