Message 1 of 5
Digital Phone
I am getting "No Number' on all my incoming calls and my phone is not taking messages.
4 REPLIES 4
Message 2 of 5
Re: Digital Phone
have you restarted the BT hub to see if that helps.  if not contact billing and get caller ID activated again
https://www.bt.com/help/contact-bt/account-and-billing/broadband
or phone CS 03301234150
Message 3 of 5
Re: Digital Phone
@susanj15
Have you recently been migrated to Digital Voice? Only, when we were last year, for some reason, caller ID got deactivated.
I was able to go in to my account via myBT online and re-order Caller Display again at no cost. I think it became effective almost immediately IIRC (Edit: within 15 minutes, actually - I've just checked the timestamps on the order confirmation email and the email confirming it was now active).
Message 4 of 5
Re: Digital Phone
Thank you for your reply.  The problem was solved after a very helpful person from BT sorted out the query.
Message 5 of 5
Re: Digital Phone
