Message 11 of 11
Re: Digital Voice and Careline use.
@Buddhagb1wrote:
I believe this would depend on the actual careline unit, for ours it needs plugging in as well as a phone line so yes. The current one available from BT is not compatible with Digital Voice and this is being looked into.
Based on previous threads I believe BT have some responsibility to ensure the system works normally.
hope this helps
As the world moves on and the PDSN system is retired is it not the care line supplier who should ensure they have a product the works?
