Message 1 of 7
Digital Voice: no incoming number displayed
My DV phone connected with an adapter, does not show incoming numbers.  Is there a setting somewhere for this?
6 REPLIES 6
Message 2 of 7
Re: Digital Voice: no incoming number displayed
Go to MyBT and enable caller display.
Message 3 of 7
I'm in MyBT but don't see where to set Caller Display...
Message 4 of 7
Found it, but it was already turned on...
Message 5 of 7
then turn it off wait and then turn back on and see if that helps
Message 6 of 7
Does CLI ( calling line information ) work when the phone connected directly into the SH2 phone port ( thus eliminating the DV adapter ), if it does then it’s the DV adapter that is not forwarding the information to the telephone handset.
Message 7 of 7
Thanks to all - I had a setting on my account which I had not completed. Seems to be working now.
