Message 31 of 42
Re: Digital Voice not configured on Hub
Thanks for your help on that DVoid.
Interesting - it all seems to come down to a lack of communication in the communication industry.
For the help of others, if you are migrating your broadband into bt you should get a SMS/Email telling you of your "service activation" date, which is great and I did, but if you are also expecting your digital voice to be activated at the same time, don't! My digital voice order was a totally separate order, (although it was all placed by me as one order), and subject to a separate time scale that wasn't communicated to me.
In my case I got an SMS from BT telling me that my "full fibre services", (note the plural), would be activated by the end of 26th. of September, but nothing mentioned about the DV service so I just assumed it would be activated at the same time, (silly me...). When I raised a query I found that my DV activation date is set for September 2nd, but no communication at all received by me on that, hence the problem.
FYI - the chat service is probably the quickest and easiest way to go - it worked well and I quickly got the above DV information that apparently "should have been sent automatically".
Message 32 of 42
BT's team on X (of twitter fame) can be good at dealing with issues, if the team still exists..
Message 33 of 42
Well, I received an SMS from BT about an hour ago saying: "Hello, BT here. Your digital voice service is now ready to use. You should now set up your equipment and plug your existing phone into the back of your hub. (Note the "NOW).
I know it's earlier than the original date they didn't bother giving me, (2nd. Sept), but hey, a text's a text, am I right? Perhaps they've actually got their finger out? Optimistic I know, (silly me again - will I ever learn...)
The 'equipment' has been running on 900Mbps broadband for a while now so all I gather I have to do is plug my existing 'phone (A Panasonic KX-TCD220E DECT cordless combo) into the green hub socket - simples! What could possibly go wrong,,,,,, BT, that's what... No dialling tone and the hub is still showing 'Unconfigured' in the 'phone section. (No, a reset has no effect and neither does a power cycle). Now I really know what my poor old neighbour Graham had to go through and at our age we don't need it... Does anyone in BT know what they are doing?
Message 34 of 42
Wow! I thought my neighbour was exaggerating when he was almost in tears as he related the sorry tale of trying to get his 'Digital Voice' phone service activated, but now I sympathise entirely with him. I won't repeat in entirety the abysmal events to date, (it's mostly documented in the thread but the final piece of the jigsaw has just fallen into place).
I spent getting on 5 hours yesterday evening talking to an advisor to try and get my Panasonic DECT combo to work by simply plugging it into the green socket of my HH2 as I was assured it would and AI Perplexity agreed, (even though it's a fairly old unit). Remember I'd already received a text from BT a day or two before to tell me that my DV service was available for use, (ordered as a number transfer). Anyway, it wasn't working - no dial tone and a 'non configuration' indication in the HH home page phone status. We spent all of those five hours setting, resetting, factory resetting, plugging and unplugging, photographing all my kit and the rear of the home hub and uploading them to no avail. Shortly before 9pm we'd both had enough and the advisor came to the conclusion it was my phone and ordered a 'digital adaptor' for me, (I gather basically a wall mains socket 'wart' to provide power that accepts the standard phone plug and communicates over wifi with your HH2 so even the dumbest of phones can perhaps work). So, I was stuck waiting for delivery for this, but this morning I received two sheepish SMSs's from BT, (what little they do send always comes in pairs), to say "Your digital phone service is now ready for use". Without much hope I plugged my Panasonic DECT combo into the green socket and Yay! dialling tone and it's now showing configured on the HH home page. So, to echo what a previous member says, if you encounter this problem, (no dialling tone and 'Non Configured' message on the HH2 home page), THEN IT HASN'T BEEN REMOTELY CONFIGURED, (you can't do it!), and you're wasting your time as I was until the relevant team, (I'd guess Openreach but I may be wrong), configure your hub remotely as a previous member said. Unfortunately BT do not seem to have told their advisors this and it is an uphill struggle to try and convince them that a dumb customer might just be right - good luck with that! (I didn't quite make it...).
Is that the end of it? NO - the hub phone status now shows that the hub has finally been configured, but they've not transferred my home number, (as per the order), so I've now got the wrong telephone number. Aaaaaaaaargh... Oh God here we go again..... I have to agree with my neighbour - I have honestly never come across such staggering levels of incompetence, ever! BT have got to get their act together on this!
I hope all this helps others... (Print this out and give a copy to every advisor...).
Message 35 of 42
It's not the hub where the configuration was lacking, it's the 'exchange'. The service hadn't been configured correctly.
Unbelievable the 'guide' could consider it was your phone at fault with the hub displaying "not configured' for Digital Voice and that an adapter (which you plug your phone into) would somehow miraculously make it work!!!
Message 36 of 42
Thanks for that clarification.
Unfortunately, as the team leader for our successful local FTTP broadband community scheme a couple of years ago I had to deal directly with Openreach for some time and I came to realise that Openreach are not exactly what you'd call "customer orientated", (understandably, given their wholesale WOS position, of course). Mind. something really needs to change IMHO, given my neighbour and my similar unacceptable nightmare experiences.
Edit: BT have raised an order to get my old telephone number reinstated. I feel like I'm walking on eggshells all the time wondering what could possibly go wrong next. I can anticipate one thing:  following my original Migrate+DV order I was assured my 700 minutes call plan would be honoured..... what are the odds do you think?
Message 37 of 42
Those days are long gone, they fired everyone and got in sales people. I had one send me a 4G modem to plug my phone in to..
Message 38 of 42
Another small example of BT world:
Going back to my very first post here, when an engineer came to visit nominally to fix the phone issue. The protocol is that they should phone 30 mins beforehand to make sure of access. On arrival he announced that he was an Openreach engineer, come to fix the broadband, and apologised for not phoning. This was because the contact number he's been given was for the landline that didn't work!
Message 39 of 42
Quite,
Oh well, at least I eventually got my old telephone number reinstated this morning after a very frustrating battle. No sign of my 700 minute calling plan, that I can find, though. I know they don't offer it any more, but that didn't stop them offering it as an incentive for me to move my account to them as in "don't worry, Mr. X, we will reinstate your 700 minute calling plan at the end of your order".  I wonder if it's a valid reason to cancel the contract? I don't think I can afford BT's call charges..
Message 40 of 42
The unlimited calls is not much more than the old 700 minutes plan.
