Message 1 of 5
Digital Voice not working
I wanted to change to Digital Voice and received my Smart Hub 2 in February with instructions to connect my phone to the back of my hub. Since then I still can't make or receive phone calls and the order on my account is still showing as "open". I have telephoned BT numerous times but this problem still hasn't been corrected. Plugging my phone into the telephone socket doesn't work.
4 REPLIES 4
Message 2 of 5
Re: Digital Voice not working
Message 3 of 5
can you go to hub manager by entering 192.168.1.254 into your address bar and see if your phone number shows and if does it say active.  if not configured then you need to contact CS 03301234150 and they should help
Message 4 of 5
BT have now solved the problem. Thanks for your reply.
Message 5 of 5
I'm glad to hear that it's been sorted out for you, @Smallgal.
Thanks for coming back to let us know.
Chris
