Message 1 of 13
Digital Voice switch over not working?
Hi, we swapped over to Digital Voice this morning.  I have been a BT broadband customer for years, so already had a Smart Hub 2, and assumed that once Digital Voice was active, I could simply plug my phone into the phone port on the back of the Smart Hub 2.
The phone is a BT4000 twin, but now I get the 'check line cord' message on the handset, no dial tone and if I call my home number it bounces straight to Voicemail.
I had a look at the Smart Hub Manager, and the phone icon shows as 'Not configured'.
Have I missed something here, do I just need to wait a little longer, or have BT not quite done everything to fully move me over to the new service?
Thanks,
Chris
12 REPLIES 12
Message 2 of 13
Re: Digital Voice switch over not working?
Message 3 of 13
When I was switched I found the hub needed a reboot to pick up the new settings.  (It doesn't seem to tell you that anywhere).
Message 4 of 13
On switch over day it can take up to midnight for everything to work but it is always worth a reboot of the hub or even a factory reset (by holding the reset button down with a pin or pen till the light goes from blue to green)
Message 5 of 13
Thanks, I'll give it a few more hours and then reboot the router tomorrow morning and see what that does!
Message 6 of 13
Just keep in mind if you do a full factory reset it will clear any custom settings you've put in, (and any phone contacts, although I suppose that's not relevant if it isn't working yet).
Message 7 of 13
@Chris_S987654321
Just bear in mind the above post and remember that settings for the hub and for contacts can be backed up and later restored if a factory reset is required.
Message 8 of 13
I waited until lunchtime, and did a full factory reset on the hub.
And it's made absolutely no difference at all.  I'll give it until tomorrow to see if the digital voice settings get picked up and applied, but after then, what are my next steps?
Message 9 of 13
you can phone CS 03301234150
or you can try message us here  https://www.bt.com/help/contact-bt/technical-support/full-fibre
Message 10 of 13
I did an Instant Message Chat with the helpdesk and they looked at my set up, got me to try connecting the phone again, and I assume checked some things in the back end.  However, they also mentioned some issues with their remote tools, but it wasn't clear if that was an issue at their end or mine...
So this evening I had a look at the Smart Hub 2 Manager, which still shows as 'Not configured' for voice. However, I also checked status and the firmware updated date.  It reads:
Firmware version:  v0.17.01.12312-BT
Firmware updated: 9-Jul-2020
I assume I should have expect an update or two to the Hub over that time?
Could that be the issue here, for some reason my Hub isn't pulling down firmware / settings?  And if so, how do I get it 'unstuck'?
