Message 1 of 8
Digital-Voice
Original set-up o.k. but I have inadvertently turned off all incoming calls, so nobody  can contact me. How can I correct this?
7 REPLIES 7
Message 2 of 8
Re: Digital-Voice
Have you accidentally activated Call Diversion
Message 3 of 8
Re: Digital-Voice
Hi Les. Thanks but cancelling call diversion does not sort out the problem. Still no calls getting to me. flyer32
Message 4 of 8
Re: Digital-Voice
Further to the above,I did a test call which had no rings although the phone number was shown
and the call was sent to 1571. Could it be a Sound problem?
Message 5 of 8
Re: Digital-Voice
Check MYBT   go manage package then digital voice and check you don't have 1571 set to answer immediately so phone does not ring as goes direct to voicemail
Message 6 of 8
Re: Digital-Voice
Checked Mybt and the 1571 delay was set to 7 rings, so it's not that. Took the opportunity to set delay to 10 rings.  My son tested the problem,and thinks I have dialling rings too low or "off".He
said he could hear the dialling rings from his calling phone. How do I set dialling sound back on?
Message 7 of 8
Re: Digital-Voice
@flyer32 thanks for posting, I'm sorry to see your phone isn't ringing. What phone handset are you using?
Neil
Message 8 of 8
Re: Digital-Voice
 Hi  Neilo, The handset is  an "Advanced Digital Home Phone", and my son has fixed the problem
and incoming calls now ring O.K. I don't know what he did but I would like to know for my own
satisfaction. I need to know how I messed it up in the first place. Many thanks
