Message 1 of 4
Digital voice handset
So i am right in thinking that BT no longer give out handsets for digital voice? Is there a way of getting a discount on the new equipment, also does the handset have to come from BT direct or can I buy it from another supplier seen some sources cheaper than ee store
3 REPLIES 3
Message 2 of 4
Re: Digital voice handset
@Geord
They are no longer supplied free, however you can still use your existing phone by plugging into the phone socket on the back of the Smart Hub 2.
If that is not convenient, then BT will supply a free BT Digital Voice Adapter which your phone plugs into.
Message 3 of 4
you can buy a DV phone of Ebay like many people do but obviously no guarantee
Message 4 of 4
