Message 1 of 2
Digital voice no called ID
Hi. I have had problems with Digital Voice phone not showing caller ID. Made three calls to BT AND IT NOW WORKS.  Apparently there are two Caller Display features.  I had the caller display active so it wouldn’t work.  Because I have the BT Caller Protect BT had to add the Caller display with privacy at home.  They placed the order and it’s now working. Good luck.
1 REPLY 1
Message 2 of 2
Re: Digital voice no called ID
Hi @LB1957 and welcome to our community.
Thanks for posting about your Caller ID with Digital Voice. We really appreciate you taking time to post this as I'm sure it will certainly help other members of the community who have a similar problems.
Cheers
David
