Message 1 of 13
Digital voice problem
Hi.  I was converted to DV several weeks ago.  The broadband is fine, but there is no landline.  The phone is plugged into the router OK.  I registered the problem with BT and they logged it as fault.  Since then NOTHING has happened and it is impossible to get any news - they just respond that the fault has been noted.  Any thoughts?
12 REPLIES 12
Message 2 of 13
Re: Digital voice problem
can you go to hub manager  192.168.1.254 into address bar   can you see your phone number and is DV active?
Message 3 of 13
Hi @pc1795,
Welcome to the Community!
When you've called the team have they advised of what will be happening next, or a timescale?
Rach
Message 4 of 13
Hi again.  Sorry about the delay.  I've looked in the Hub Manager and the phone is marked as "not configured".  BT say they are "still working"  on the problem, after more than 6 weeks!  We'll see!
Message 5 of 13
Hi.  I've been unable to call BT, and when I go online they just say that the problem has already been reported and is active.  There has been no news at all for over 6 weeks.  Very frustrating!
Message 6 of 13
can you go to help at top of forum page then either raise fault or trace fault and see if you can see your fault
Message 7 of 13
Yes,I raised the fault on 13.Feb. A
Message 8 of 13
Yes.  I raised the fault with BT on 13th Feb and they logged it.  I have been tracking it and nothing has happened - it just sits there saying they're ' still working on it'.  I can't t raise it again as they say it is already logged.  I even tried to complain and got redirected to the Track fault link again.  It is also very annoying!
Message 9 of 13
try using the consumer email address in this link and hopefully you will get some action on your fault
https://www.bt.com/bt-plc/assets/documents/about-bt/policy-and-regulation/our-governance-and-strateg...
Message 10 of 13
Hi once more - just following up on my DV problem (no landline since installed, broadband OK).  I've tried everything, including a 150min(!) 'chat' with a bot.  I was told all is OK, and BT sent an email closing the fault.  Guess what - it still doesn't work!  I give up.  Thanks for your help, but this obviously can't t be fixed.
