Message 1 of 4
Diverting BT landline to mobile without handset
Hi folks
I need to access my landline number to obtain a pin code from my insurance provider.   I don't have a landline handset.   Is there a way to divert/forward landline calls to my mobile without one?
Thanks (and apologies if this is a silly question).
3 REPLIES 3
Message 2 of 4
Re: Diverting BT landline to mobile without handset
No, it can only be done from your line, for security reasons.
Message 3 of 4
Can you not just borrow one from a neighbour or simply buy a cheap handset from Amazon or Argos?
Message 4 of 4
Yes, I'll sort something out.
