Message 1 of 4
Elderly and vulnerable phone line fault, no fix until Thursday?!?
My father is elderly, vulnerable, fall risk, has crohn’s and an emergency pendant which he (and we) rely on.
His home phone line has a fault which means his pendant is no longer working, but he is a fall risk and we rely on it for help, he also struggles to use a mobile phone. The fault on his line has been reported to BT but they say it won’t be fixed until the end of Thursday!!! I have researched now we have a fault and realised you need a form signed by a Dr to get him registered as vulnerable with BT, which is fine but you only find that out when you have a fault on the line and is no use to me right now. We don’t live close enough to go and stay with him until the line is fixed, this situation is utterly ridiculous, he can’t be without his pendant and home alone until Thursday!!! Is there anything I can do to get it sorted quicker? I have tried calling BT but they just quote the form being filled in!
3 REPLIES 3
Message 2 of 4
Re: Elderly and vulnerable phone line fault, no fix until Thursday?!?
Hello @Vicki76  I have asked a passing moderator to get in touch due to your fathers needs, only the moderators are BT employees.
Can I also suggest looking at what else BT can offer customers who need extra support, have a look at www.bt.com/hereforyou
Message 3 of 4
I suggest you get back onto BT and ask that they raise it as an emergency welfare case with openreach. This will get an early visit by Openreach however depending on the outcome of this it may still take further time to repair if the engineer has to pass the fault in to another department.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 4
Hi @Vicki76 and welcome to our community.
I'm sorry your dad is having problems with the line. I'll be happy to take a look at this and check if there is anything we can do to help. Please check your inbox for my message and drop me a reply with the details.
Cheers
David
