Message 111 of 137
Re: Elderly/vulnerable customers without Broadband - Notification of new Digital Voice service
OK, if no-one knows that would explain the people assertively stating mutually contradictory positions, and getting stroppy when everyone doesn't believe their One True Faith.
I'll just have to accept that BT haven't yet thought adequately about how to preserve service if people like my mother, and we'll need to prepare ourselves for a potential battle get them to behave decently when the time comes.
Message 112 of 137
@blackprince
Though many explanations have already been given and you appear to not understand them, I thought perhaps I would try as well.
Back in the day I can remember in my first job when 'Broadband' first came on the scene...
You had a phone line and a phone service on the PSTN network.
You purchased a broadband service that ran over this phone line using difference signals that didn't interfere with the phones (when using filters when necessary).
So the phone service could be with, say, BT but you could have Freeserve as your ISP, for example.
Not a problem. Different types of signalling, shared on one copper pair.
But PSTN is being switched off and the phone service will now use Internet Protocol packets to deliver the call data, in the exact same way websites are displayed and the such, what we know as 'the internet'.
So, herein lies the problem.
Each ISP is now no longer allowed to offer a PSTN phone service so their options are: offer no phone service, or, offer a VoIP service as a replacement that uses IP packets.
Some ISP are choosing to dump the home phone idea.
Others are choosing to offer the VoIP solution.
So your options here are these:
If you wish to keep your phone with BT you 'MUST' use their broadband service to have it delivered 'by BT' - this is Digital Voice, but to all intents are purposes, call it BT Phone. BT Phone is provided by BT so would need BT Internet to deliver it.
If, however, you wish to stick with your current broadband ISP, if 'they' offer VoIP, you can try to get your number ported from BT to them — or take a new number. If they do not offer VoIP, you can go with a "third party VoIP provider" — I will elaborate on that next.
If, however however, you wish to stick with BT or your Broadband ISP but do NOT want their phone service — well, you don't have to have it. You can 'STILL' opt to port your number to a "third party VoIP provider". That's not a problem.
So, to 'replicate' if you like, what you already have, you could have your broadband with 'whoever it is with' and then have someone else entirely provide your phone service.
The sticking point that is being contradicted is, if you want to STAY with BT for your phone, you MUST use their broadband to deliver their phone service. Just like you can't order a Big Mac at Burger King. Even though they both do burgers.
But you can always go to Burger King and get a generic burger from the burger van down the road  —  no one is stopping you.
As for your mum, my dad is 84 (just turned) and luckily he had a son who is an IT Engineer. For those not as lucky, then yes it will be a change. But as others have pointed out, just because you don't like it, doesn't mean its not fair or not happening. So:
Internal telephone extensions. No, BT aren't going to change that for you. You say that they are going to break it and therefore should fix it? Well, I am going to assume, unless the house is old, they probably didn't put the extensions where they are right now — and if they did, as I said, it would have been a long time ago when Post Office Telecommunications were still solely responsible for such (in which case the wiring needs updating) or they were paid to do so. Otherwise, someone likely had a handyman put them in. Either way, Openreach is only responsible up to the demarcation point of their network. That is in a lot of places at the point where their wires enter the house — in my case its where they enter the house and carry on into a junction box, then to the Master Socket. One way or another, they are responsible up to the 'back plate' of the master socket only. The front plate onwards is, and has been since the mid 1980's your responsibility. That is where the extensions connect, and where they then go. Sorry that you do not find that convenient but it is true, and so… what do you do about it?
Well, simple actually. You attached the extensions to the green socket on the back of the Smart Hub 2 — you don't have one of those (yet) at your mother's house, and so, you can't really 'plan for it' until you do. As I am sure detaching the extensions right now will cause your mum more of a pain as you have nothing new to connect them to. As to 'how' you go about this, when the time is right, there are multiple ways you can, all of them logical and you would have to choose at the time the way that best suits your needs. Mine is just extended out from the bottom of the master socket where it used to be joined, and a BT plug is on the end of that, plugged into the router directly. Yours may have to be different.
I think everyone else has covered the rest as well or better than I would anyway and this is a very long post. Hopefully it is helpful, if not then, I apologise for being not very helpful.
Message 113 of 137
I have in preparation for DV removed 5 or 6 landline corded phones from around the house so just have the two separate numbers (landlines numbers) with  corded phones coming into my home office now. I felt I might as well start preparations and get things a bit simpler for when BT send us the hub/hubs 2 for digital voice. ALthough so far it feels like I jumped the gun - I was told BT were moving London to digital voice by end of 2023 and here we are into February and nothing has yet happened. I just to know exactly what will hapen with things and when including the 20+ differences I have so far found out often via here as to what will be different which I don't think BT list as well as they might. I don't want to be told it is simple if lots of things are different - eg taking the phone off the hook which I do every day when I pop into the garden or go off so it goes to call minder as soon as someone rings in - completely different with DV, should be put on a list to customers along with all the other differences rather than conning people into thinking you just plug the phone into a new modem you will be sent as if that were the only change!
Message 114 of 137
VoIP
ofcom describe it as an upgrade, the truth is it’s a step backward and being forced through by the government, ofcom and telecommunications companies, they really don’t care about the non tech savvy and they don’t want them to understand what is happening and the real reasons
the switch to voip is so shortsighted, putting all your eggs in one basket et al…..
in a so called democracy we are not being given any choice or say in this
if the internet goes down due to any circumstance we will no longer have communication
I am a telecommunications professional and the only benefit is to the providers who no longer have to maintain telephone exchanges and their battery backup systems.
off com indeed
Message 115 of 137
Also as usual it’s about de-skilling and reducing the number of employees
I could go on about DAB v FM and DVB, don’t be fooled in most ways they are not a step forward
Message 116 of 137
Thank you so much for raising this concern as my mother in law has no broadband and we do not have mobile signal. The answers are reassuring. However, we/she has to phone BT to tell them of our situation, which is a challenge in itself. I'm hoping BT is monitoring these messages and will either provide a specific phone number for digital voice to make phoning less stressful, or enable us to contact them digitally.
Meanwhile, well done
Message 117 of 137
@bevjones9  This is just a polite observation, but you have responded to a thread last contributed to 16 months ago. It isn’t a criticism, merely that some of the contributors will have moved on from the thread long ago and you may not get any responses.
Message 118 of 137
Good afternoon @bevjones9.
Welcome to the Community!
Digital voice calls work on the same numbers as normal phone calls, so there isn't a dedicated number for digital voice queries.
If your mother in law is able to move to an area with a signal, I'd recommend her giving our broadband fault checker a try.
You just need to send us a text with HELP to 66033, and we will run some troubleshooting on her phone and hub, and if needs be help arrange an engineer appointment too.
Just as a heads up as well, if she is vulnerable have you had a chance to register her details here?
Here For You | Help for customers with an impairment | BT Help
Peter
Message 119 of 137
I really don't think you got it. My mother in law is 93, she doesn't want broadband. We are farmers so have to live on the farm. BT needs to adapt to their customers needs, not customers to BTs
Message 120 of 137
You do not need to have broadband in order to have Digital Voice phone.
It will work along the same line that goes to her house. She will be supplied a small device that she plugs her phone into instead of it being plugged into the phone socket on her wall.
If she is not able to fit it herself BT will arrange for a fitter to install it for her.
