Message 11 of 26
Re: Engaged tones on all extensions
Hello
OK so I left my router unplugged for about 35 minutes and switched it back on again
Unfortunately this hasn't had any effect
So I still can't dial out!
Anybody got any more suggestions?
Message 12 of 26
Looks like you are going to have to bite the bullet and report the fault.
0330 1234 150
Message 13 of 26
Looks like it
Was hoping it was just something simple
It's weird how we can still get incoming calls!
Message 14 of 26
@Mike0000
Looks like the outgoing server is either congested, or faulty. Could be a faulty network router, but that would affect other users as well.
It could also be a faulty configuration within your home hub.
I wonder if you exported your contacts first, then did a full factory reset of the home hub to remove any possible corruption of the settings, then see if you can make outgoing calls.
If you can, then import the numbers again, and see if it still works.
Message 15 of 26
Sorry getting a bit technical for me now!
by contacts, do you Just mean the numbers we have stored on the phones for dialling people like friends etc?
How do you do a factory reset?
thanks
Message 16 of 26
(Yet another reason I dread Digital voice (it is so much worse or I expect it will be for me)  - I have never had a problem like this on my landline in 25 years....)
Message 17 of 26
@Mike0000
Backing up of the contacts is only needed if you are using any of the BT supplied phones that connect directly to the home hub, as the numbers are stored in the home hub.
Any stored on other phones are not affected.
For factory reset see https://www.bt.com/help/broadband/how-do-i-reset-my-bt-hub-to-its-factory-settings
Once that has completed, you will have to re-register any Digital Voice Adapters, to the home hub. Also any of the BT supplied handsets.
The chances are that the helpdesk would advice a factory reset to start with anyway.
Message 18 of 26
thanks
With Digital Voice your contacts (numbers) are stored in the hub not the handsets. Unfortunately a factory reset wipes these. You can backup the file and restore it again after the factory reset. Go to the hub manager (192.168.1.254) click on the phone symbol with your number against it, select Contacts, enter the admin password for the hub printed on the little pull out tab, select Export. This will export your contacts list to a .VCF file on your PC. After the reset, import the contacts back again.
To factory reset the hub, press the recessed button at the rear with  a pin for about 20seconds until the lights flash.
Message 19 of 26
Thanks very much all
Gonna speak to BT on this now before doing anything else
Bit scared to do the factory reset incase it goes wrong and then I have no Internet either!
Will report back if and when it gets sorted,  for anyone else who gets this issue
Thanks again for your time people - appreciate it 🙂👍
Message 20 of 26
I strongly recommend you do the backup before calling BT in case they do a remote factory reset and wipe your contacts.
