Message 21 of 26
Re: Engaged tones on all extensions
A factory reset will not stop Internet access, it just restores it to a known state, and can even be initiated by the helpdesk.
Message 22 of 26
@Jane2018 wrote:
(Yet another reason I dread Digital voice (it is so much worse or I expect it will be for me)  - I have never had a problem like this on my landline in 25 years....)
If you continue to use your existing phones and not the new DV phones (which are no longer supplied free) then a factory reset will have no affect  on your list of. Contacts stored in your existing analogue phone.
Another problem solved
Message 23 of 26
Hi There im reading your post from January 2024 and im getting exactly the same problem now?
Did you get it solved
constant engaged tone when dialling out but can receive calls?
Message 24 of 26
Hello
We had to email BT and they said the issue was something at their end
About two days later they resolved the problem
They did whatever they did remotely,  no engineer came to our house
So I would email them and hopefully they can sort it
I'm afraid I don't know what was causing it....
Message 25 of 26
Hi
Do you remember was email address you used for BT customer service?
Many thanks
Message 26 of 26
Sorry I can't find it
But if you Text HELP to 61998 they will get back to you to discuss your issue
Good luck!
