Message 1 of 3
Error Message on BT Advanced Digital Home Phone with Alexa built-in
The repeated error message on the screen is "Unable to update you right now. We'll update you later."
If you try a manual update the phone states Checking for new Software -> Software Up to date
Is there a bug or a solution please
2 REPLIES 2
Message 2 of 3
Re: Error Message on BT Advanced Digital Home Phone with Alexa built-in
Have you tried going into phone menu and then select reset.  You will have to set up phone again but see if the sorts out update
Message 3 of 3
Thank you, I have. It keeps coming back
