Message 11 of 18
Re: Extension phone on DV not ringing
The issue, as I understand it, is that old* phones need the 3rd "bell" wire connected.  This wire actually taps off from one of the two main wires and some filters simulate this, so I suggest you look for one with three pins connected.
Whether the product descriptions will be up to that I don't know.  (In my experience as an IT tech, Amazon IT product descriptions are often inaccurate to the point of being comical).
*I'll also point out, because it's not been made clear, but this issue only applies to old phones, so it might be worth waiting and seeing if your phone works without it.
Message 12 of 18
Thanks again WSH. The phones are 7 years old, called BT Essential, a set of three, one in the hallway next to the hub, one in the bedroom and the other in the living room. I always carry one around with me in the garage and garden etc.and it has always rung when I have had a call. Now it doesn't since the change over. I'm not very mobile and that is the reason I carry it around as I can't get to the phone quickly. I changed the batteries last week as the others were the originals.
Anonymous
Not applicable
Message 13 of 18
@Trader1
I recall the scenario @WSH described, but I can only remember one incident, so I think you'd be unlucky to pick one that doesn't work. But having said that, I wouldn't have thought those phones would be an issue. I guess the only way to find out is to try one.
If you're on Facebook, maybe ask locally if someone has one spare, there's probably dozens lurking in drawers. Or if you want to message me your address, I'll pop a new one in the post. I can't guarantee it will work but won't cost you anything to find out.
Message 14 of 18
@Trader1 I have deleted your post as you really don't want to be posting your home address details on a public forum viewable worldwide!
I suggest you use the DM function directly to @Anonymous
Message 15 of 18
Thank you CL licquorice for looking after me, I admit I was a little wary about showing my name and address.As I have said before I am 91 and not sure about using these forums. I must thank rbz5416 for his kindness in trying to help me. I shall go to Amazon for the item that was suggested, they don't cost much. Thanks again.
Message 16 of 18
@Trader1
I don't know your extension set up but when I got BT full fibre with Digital Voice I connected the phone socket on the BT hub to the  redundant Openreach master copper landline socket which fed all the extension points in the house & every phone worked & rang.
Message 17 of 18
Thanks caravanjI will try your suggestion. My son will be visiting soon, he is more clued up than me so I will leave it to him to sort out. Thanks again.
Message 18 of 18
rbz5416 Thanks for your reply and kind offer. You will probably have seen the later post about my posting my home address which was deleted, I realize that was the right thing to do. I am not clued up with this social media protocol. I am impressed with the help given to me by yourself and others on the forum. Thanks again.
