Message 11 of 19
Re: FTTC
Hi  WSH
In my previous, I was blindly assuming that an OR person would check that the DV changeover was OK at some or each of the properties, given the age of some of the folks around here.   I guess that this didn't happen in your case (!) and therefore my "declared as done" theme is irrelevant.
Nevertheless your response was interesting.
Endersby23
Message 12 of 19
Re: FTTC
Obviously not everyone is the same and have different levels of mobility etc , but I’d be embarrassed if as an abled bodied person I watched someone visit my home specifically to move a phone cord from one socket to another socket …I find it astonishing that some will be so entitled that they feel no embarrassment, and consider it their ‘right’ to have this done for them , a customer of Sky or Vodafone for example would get no such assistance if they were required to connect their phone to the router .
Message 13 of 19
DV Install on existing FTTC this week
Unfortunately, my diy DV Install on my long established  FTTC link earlier this week has a problem about which I'd appreciate some expert guidance.
After following the logical published DV guidance regarding what-to-plug-where in on a Smart Hub2, outgoing phone calls then seemed to work as expected.  However, incoming calls to the home DV number never appeared at all !
I've since found that only way I can currently receive any incoming calls is to ignore the hub configuration guidance and plug a conventional PSTN telephone into the master socket.  To my surprise this delivers conventional 25Hz ringing current to the phone, a DC transmission feed on answer, and loop-disconnect dialling as well !  So is this an error at the Green FTTC PCB cabinet "around the corner"?
As to settings on my Smart Hub, it appears to think that I'm a "Full Fibre" FTTP customer and seems to resist my attempt to reset it to "FTTC".  Is this setting actually important for FTTC working?
There seems to be very little guidance specific to DV over FTTC so can anybody give me some guidance please?
Message 14 of 19
Re: DV Install on existing FTTC this week
If your DV service has a dial-tone  ( so the phone connected to the router has a dialing tone ) call a mobile ( your own preferably ) and check the calling line identity (CLI)  displayed is correct , if it is but all incoming calls to this number still appear at the wall socket , then the migration to DV is incomplete, basically the PSTN is still delivering incoming calls, FYI , to allow the number to be moved to DV from PSTN , the PSTN service is stopped and renumbered, so 50v , dialtone and a engineering number are applied so a soft dialtone remaining at the socket is usual (for a while) even with successful migrations , you could wait and it may resolve itself in its simply delayed, or  call BT and report it .
Message 15 of 19
All the hub setting to FTTP does is convert LAN port 4 to a WAN port for connection to the ONT.
It has absolutely no effect on FTTC connection to the DSL socket on the hub or DV.
DV on FTTC is exactly the same as DV on FTTP assuming it has been enabled correctly.
Message 16 of 19
Hi iniltous,
Thanks for explanation about numbering migration from PSTN to DV as I'd certainly had a few "I wonder" moments  as to how it this was being tackled and didn't know that there was a delay factor in it.
As to its impact on my (simple self install) DV over FTTC, I did report a fault because at the time, it seemed that I would be paying for a voice service that didn't allow incoming calls!   Nevertheless, the CLI checks that you suggested have shown that the situation is improving and I'll probably cancel the fault report.
  Enderby23
Message 17 of 19
Thanks,
As I will not need a WAN port in a FTTC situation, I'd prefer to have Port 4 as another LAN if I can successfully nudge the Smart Hub into letting me set FTTC working!
Message 18 of 19
Thanks,
Because I don't need an ONT WAN port with FTTC working, I'd prefer to set the Smart Hub to FTTC and keep port 4 as LAN. Nevertheless my Hub "fought back" the last time I tried this!
Message 19 of 19
There is a toggle switch for FTTP Mode under "Advanced settings" then "Broadband".
I can't remember off the top of my head, but you may have to click "Save settings" at the top of the page after you set it.
