Message 1 of 4
Gigaset compatibility
  • Hello. Have just got BT Digital Voice. BT's engineer didn't  want to spend time adding my Gigaset cordless phones A220 and C300. Is there some way I can do this? Many thanks.
3 REPLIES 3
Message 2 of 4
Re: Gigaset compatibility
Message 3 of 4
@agarnam
You can simply plug the Gigaset base station unit into the phone socket on the back of the Smart Hub 2.
Message 4 of 4
thank you - I spent some time doing various reboots - when it was such a simple solution
