Message 1 of 6
Re: Gigaset compatibility
I have just been swapped to BT digital voice. My Gigaset C300 works OK (including caller recognition) when plugged into the Smart Hub 2. However caller recognition does not work if the phone is plugged into the Digital Voice Adapter V2. Any suggestions?
5 REPLIES 5
Message 2 of 6
Re: Re: Gigaset compatibility
Message 3 of 6
@NW2Peter
Welcome to this user forum for BT Retail phone and broadband customers.
Does it ring on an incoming call?
See this post https://community.bt.com/t5/Home-phone-including-Digital/Re-Digital-Voice-Adapter/m-p/2324347#M92091
Message 4 of 6
Yes I can call out and receive incoming calls.  Problem is that caller recognition does not work when using the adapter
Message 5 of 6
Read the link I posted, there does not appear to be a solution.
Message 6 of 6
I think the ombudsman should be informed
