Message 1 of 3
How To Set Time on Essential Digital Home Phone
To set the time should be very simple, but when I select menu there is no clock option.  Any advice would be appreciated.
2 REPLIES 2
Message 2 of 3
Re: How To Set Time on Essential Digital Home Phone
does the time not set automatic from the SH2 base station and the option you get is either 12 or 24 hour clock
Message 3 of 3
Thank you - problem solved.  Instructions don't mention that.
