Message 1 of 6
Use HomeHub2 as a Slave For Upcoming Digital Voice Switchover
 I have replaced the HH2 with a set of Asus ZenWifi AX routers, one of which is plugged into the ONT. I've been told my switchover date for DV is 7th June. I have looked and now found out that I can only plug the phone into the HH2, not the Asus routers.
 My question is, can I attached the HH2 to one of the ASUS routers using an ethernet cable, then plug the DV phone into the HH2 to allow calls? Thanks for your help.
Tags (4)
5 REPLIES 5
Message 2 of 6
Re: Use HomeHub2 as a Slave For Upcoming Digital Voice Switchover
Message 3 of 6
@lippo
No that will not work, the SH2 has to be directly connected to your physical Internet connection.
Message 4 of 6
If you want to use your third party router and digital voice you will need to have the BT Smart Hub 2 connected first then connect your third party router from the LAN of the Smart Hub 2 to the WAN of the third party router.
ONT --> BT Smart Hub 2 --> Third party router
Message 5 of 6
Thank you for the quick response.
Message 6 of 6
Thanks, looks like I have some reconfiguring to do. It's going to be a pain.
